orlandosardaro
#1 Posted : Monday, March 12, 2007 2:47:49 PM(UTC)
orlandosardaro
Another issue still around:
We would so very much like to be able to select and manipulate multiple features in the feature tree at the same time!
I have attached an example. The one thing I need to change is the Cube right at the top of the tree, but I need to suppress all features underneath to be able to do that. This should really be improved now, it's 2007 and competition is busy!
The reason is that when I change the cube width it changes at the wrong side, so I need to look at the cube alone and do some local face modding.
Please improve the feature tree! Have us e.g.:
- drag features along the tree;
- click somewhere in the tree and 'suppress from here', make us jump into history
- select multiple features and suppress, delete etc. at once, change radii simultaniously etc.
orlandosardaro attached the following image(s):
Maarten den Hartog
#2 Posted : Friday, March 16, 2007 4:09:22 AM(UTC)
Maarten den Hartog
Was thanked: 4 time(s) in 2 post(s)
I will promise Tim a real TeddyBear if he implements this.
Tem
#3 Posted : Tuesday, March 20, 2007 9:46:21 AM(UTC)
Tem
I struggled with History Tree using Pro-E. More often than not it became a big barrier to my creativity and consumed hours trying to manage History Tree issues. (I hear jokes coming already). I would prefer to have associativity and constraints more than introducing a History Tree system. If the History tree could was not such a hassle as that one in Pro-E then maybe I would change my mind. Otherwise some of the suggestions sound very good.
