union7
#1 Posted : Thursday, July 10, 2014 12:10:41 PM(UTC)
union7
v9 build 1109 Windows 8.1
All shortcuts appear to work.
Except for view- rotate. Strangely rotate forward key makes the page scroll down instead. None of the other rotate directions do anything, however the same keys DO work when assigned to other actions.
On older Viacads on vista I have had this working in the past.
#2 Posted : Thursday, July 10, 2014 1:55:40 PM(UTC)
>>Except for view- rotate. Strangely rotate forward key makes the page scroll >>down instead.
Will check.
FYI, you can also use by default Shift : Arrows (up,down,left,right) to rotate the view.
union7
#3 Posted : Thursday, July 10, 2014 4:01:02 PM(UTC)
union7
AH! thanks for that tip. It works .
