ISS
#1 Posted : Sunday, October 25, 2009 3:05:18 PM(UTC)
ISS
After a lengthy absence from ViaCAD 2D/3D V6 I saw today that an update was available. Downloaded and installed the patch/build 852.
Question I have.....what does it do? I don't see any noticeable difference.
Steve.M
#2 Posted : Sunday, October 25, 2009 4:03:29 PM(UTC)
Steve.M
You can find a change log here
- Steve
ISS
#3 Posted : Monday, October 26, 2009 6:23:28 AM(UTC)
ISS
Thanks Steve, I was kind of hoping it would fix a problem I have with ViaCAD.
Every few minutes VC hangs and I need to go to Task Manager to 'end the process' but cancel it rather than go ahead with it. That way I can continue working but it's annoying to say the least hence I have been using other CAD program.
Steve.M
#4 Posted : Monday, October 26, 2009 6:33:09 AM(UTC)
Steve.M
If you can reproduce the steps then you should report it.
Post here then others can see if they can also reproduce the problem
Could it be a problem with the display driver?
- Steve
ISS
#5 Posted : Monday, October 26, 2009 2:07:47 PM(UTC)
ISS
You might have a point there..... now that you mention display driver I think it happens when I do a lot of zoom in/out (which I do frequently)
Doesn't happen with Alibre though and neither does it happen with Vectric Aspire and because of the maximum 3 installations I have installed VC only on my laptop (Acer Travelmate 2410 series , XP Pro SP3)
Steve.M
#6 Posted : Monday, October 26, 2009 3:53:03 PM(UTC)
Steve.M
There is a bug thread concerning problems with wheel mouse zoom http://forum.punchcad.com/showthread.php?t=2458 Could that be the same problem? If it is, then you should add to that thread.
- Steve
