When I draw a horizontal wall .. It gets automatically dimensioned When I draw a vertical wall .. The dimension is not shown - but the arrows are Anybody else seeing this ?
Hi, Jol Have not seen this with vertical single or multi wall. Regards Jason
well thanks for checking Jason - perhaps it's a Mac only issue !? would someone mind checking for me ? seems to repeat every time here
Jol, I cannot repeat on the mac either. If you can send the file that would be great. Is it possible that this a text font size issue? Tim
Thank guys
it's very odd Tim .. if I start a new session and draw one vert wall and one horiz wall .. I see only one dim
will try to mess around with it further - must be a reason !
(15kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: jol Anybody else seeing this ?
No.
I never used this tool before but it seems to work here...
JL
(13kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
