2D Drafting
Spiral (helix) decal value (#2468)
Hi Tim I've been trying to get a certain result with the helix tool and have discovered by playing in AI that I need a helix with a "decay" Is there any chance that this is something you could add to our tools Thanks Jol
Thanks: 199 times Was thanked: 164 time(s) in 113 post(s)
Hi Jol, Just out of curiousity, what result is expected. Larry
Jol.
I'm just guessing what you might be after, but I came up with the result in the second and third pictures by using the Twist tool. Is that something like you want?
Martin.
(105kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
Hi Larry I can think of several uses for acceleration in a spiral - in this case it's pretty low tech .. it's for a hanging kid's mobile - spirals that turn in the breeze The spirals are simply more interesting if they are not simple offset coils - but widen or narrow as they fall
Hi Jol,
I have one made of wood pieces, low tech, but it works.
(1,489kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Hey Larry - that's brilliant !!
Jol
You could try and use the File: Import Spline which has the ability to construct splines from equations. Example attached with a quadratic and cubic coil expansion.
helix.txt.zip
(1kb) downloaded 6 time(s). Tim Olson attached the following image(s):
(49kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Hi Tim,
Is there a helix.txt file that could be used to produce the clock fusee part discussed in
http://forum.punchcad.com/showthread.php?t=2462 Thanks, Larry
Originally Posted by: L. Banasky Hi Larry,
If you can define the curve as an equation of x,y & z we could come up with a helix.txt file.
For the helix in previous post the x,y,z are...
LAWSPLINE
0
40
vec(cos(u),-5 +sin(u),(u/20))
where
Min U value = 0;
Max U value = 40
x = cos(u)
y = -5 + sin(u)
z = u/20
>> Hi Tim, The import spline file looks for an extension of .spl. I know that you are very busy, but if you do have time, post an example on how to use helix.txt. Thanks, Larry
Originally Posted by: Tim Olson Jol You could try and use the File: Import Spline which has the ability to construct splines from equations. Example attached with a quadratic and cubic coil expansion. Tim
Thanks Tim for text file, it works well. Just what I was looking for. See attached files
Windows ViaCad 2D3D
chipmaker2 attached the following image(s):
(98kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
2D Drafting
