#1 Posted : Saturday, July 25, 2009 2:46:53 AM(UTC)
Hi Tim
I've been trying to get a certain result with the helix tool and have discovered by playing in AI that I need a helix with a "decay"
Is there any chance that this is something you could add to our tools
Jol
L. Banasky
#2 Posted : Saturday, July 25, 2009 8:42:23 AM(UTC)
L. Banasky
Hi Jol,
Just out of curiousity, what result is expected.
blowlamp
#3 Posted : Saturday, July 25, 2009 11:06:34 AM(UTC)
blowlamp
Jol.
I'm just guessing what you might be after, but I came up with the result in the second and third pictures by using the Twist tool. Is that something like you want?
Martin.
#4 Posted : Sunday, July 26, 2009 4:08:23 AM(UTC)
Hi Larry
I can think of several uses for acceleration in a spiral - in this case it's pretty low tech .. it's for a hanging kid's mobile - spirals that turn in the breeze
The spirals are simply more interesting if they are not simple offset coils - but widen or narrow as they fall
L. Banasky
#5 Posted : Sunday, July 26, 2009 10:56:07 AM(UTC)
L. Banasky
Hi Jol,
I have one made of wood pieces, low tech, but it works.
#6 Posted : Sunday, July 26, 2009 1:32:52 PM(UTC)
Hey Larry - that's brilliant !!
#7 Posted : Wednesday, July 29, 2009 7:43:56 PM(UTC)
Jol
You could try and use the File: Import Spline which has the ability to construct splines from equations. Example attached with a quadratic and cubic coil expansion.
helix.txt.zip (1kb) downloaded 6 time(s).
L. Banasky
#8 Posted : Friday, July 31, 2009 3:39:25 AM(UTC)
L. Banasky
Hi Tim,
Is there a helix.txt file that could be used to produce the clock fusee part discussed in http://forum.punchcad.com/showthread.php?t=2462
Thanks, Larry
#9 Posted : Friday, July 31, 2009 11:04:00 AM(UTC)
Originally Posted by: L. Banasky Go to Quoted Post
Hi Tim,
Thanks, Larry
Hi Larry,
If you can define the curve as an equation of x,y & z we could come up with a helix.txt file.
For the helix in previous post the x,y,z are...
LAWSPLINE
0
40
vec(cos(u),-5 +sin(u),(u/20))
where
Min U value = 0;
Max U value = 40
x = cos(u)
y = -5 + sin(u)
z = u/20
L. Banasky
#10 Posted : Friday, July 31, 2009 11:29:48 AM(UTC)
L. Banasky
Hi Tim,
The import spline file looks for an extension of .spl.
I know that you are very busy, but if you do have time, post an example on how to use helix.txt.
Thanks, Larry
chipmaker2
#11 Posted : Sunday, August 23, 2009 12:06:53 PM(UTC)
chipmaker2
Jol
Thanks Tim for text file, it works well. Just what I was looking for. See attached files
Windows ViaCad 2D3D
chipmaker2 attached the following image(s):
3D spring.jpg (98kb) downloaded 7 time(s).
