#1 Posted : Friday, July 25, 2008 9:24:36 AM(UTC)
Deform to curve just doesn't work right !
Why ?
You select a surface .. then you select a constraint curve.
Sometimes the face will move .. however, I've literally never had it hit the constraint curve
Often, it doesn't move - yet the feature tree says that it's now a 'deform face'
#2 Posted : Friday, July 25, 2008 9:26:46 AM(UTC)
oops .. here's the image
deform face to curve crapola.png (18kb) downloaded 6 time(s).
Steve.M
#3 Posted : Wednesday, July 30, 2008 7:19:28 AM(UTC)
Steve.M
Hi jol,
Is it supposed to work on surfaces?
It works OK on faces of solids (shark FX 737 PC), to hit the curve I just need to enter a very large Gain size.
- Steve
#4 Posted : Wednesday, July 30, 2008 8:50:43 AM(UTC)
you're quite right Steve, I am having some success with solid 'faces' and extremely high numbers like 50,000
However, it allows the selection of surfaces .. just like bend and thicken tools do. But the results are rubbish
Perhaps it should just not allow you to select surfaces !?
Steve.M
#5 Posted : Wednesday, July 30, 2008 9:15:20 AM(UTC)
Steve.M
Hi jol,
I agree, certainly one for Tim to clarify.
- Steve
#6 Posted : Wednesday, July 30, 2008 9:06:24 PM(UTC)
Fixed in next upload.
#7 Posted : Thursday, July 31, 2008 12:54:45 AM(UTC)
Tim .. that's a HoooooJ thing for me
Thanks !
Guest (6)
