Chris CA
#1 Posted : Thursday, September 4, 2008 7:53:14 PM(UTC)
Chris CA
When using two screens (Mac OS X), I drag the main window to the second (it™s larger).
However, the top of the window on the 2nd screen will not go higher than the Prompt/info window/pane at top of the main screen.
Any way to fix this?
UserPostedImage
ttrw
#2 Posted : Saturday, September 6, 2008 3:35:23 AM(UTC)
ttrw
Also worth mentioning that if a second, larger screen is used, when the screen is returned to the smaller screen (in my case my Macbook Pro), the window doesn't resize. Subsequently pressing command-F zoom extents to the size of the larger window, not the smaller.
