I can't form a closed Net Surface
In the case of this bottle, it means that I have to make 2 halves
(I dont want to do this because I never have any luck with the match surface tool)
So .. can we have an option to close a network surface ?
closed net surface.sfx
(239kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 6 times Was thanked: 29 time(s) in 16 post(s)
Originally Posted by: jol I can't form a closed Net Surface In the case of this bottle, it means that I have to make 2 halves (I dont want to do this because I never have any luck with the match surface tool) So .. can we have an option to close a network surface ?
Hi Jol,
I usually do such stuff with skin solid->change object type to surfaces and delete surfaces not wanted. Disadvantage: No history. But I strongly agree with you that we need such a surface tool. And the best is: The technology behind such a function is already there!
(55kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: jol So .. can we have an option to close a network surface ?
Yes please, and for loft/sweep?
Originally Posted by: ALBANO I usually do such stuff with skin solid->
I always see problems from trying such a path. Could you please show the steps you made to create the solid (when you have time).
Regards,
- Steve
