Albatrossflyer
#1 Posted : Monday, February 24, 2014 12:40:33 PM(UTC)
Albatrossflyer
Is there an easy way to model a duct with dissimilar ends? What I'm looking for is the Tube Surface command with the flexibility of the Skin Solid command. Basically I need a surfaced duct with a circular opening at one end and a rectangular opening at the other end. The attached file shows what I'm after.
Duct.sfx (24kb) downloaded 7 time(s).
zumer
#2 Posted : Monday, February 24, 2014 2:30:27 PM(UTC)
zumer
Do you want gradual transition over the entire length of it, or the most obvious result? Net surface behaves similarly to skin solid, but the profile doesn't have to be closed.
duct2.sfx (509kb) downloaded 7 time(s).
Albatrossflyer
#3 Posted : Monday, February 24, 2014 3:33:39 PM(UTC)
Albatrossflyer
The Guide Skin Surface command did the trick. Thanks....
Albatrossflyer
#4 Posted : Monday, February 24, 2014 3:41:36 PM(UTC)
Albatrossflyer
