Solid Modeling
Align tool and bounding box incorrect with some split solids !? (#1941)
Align tool and Bounding Box tools are incorrect with split solids made from trimmed surface data ? Some objects are incorrectly measured by Verify>Bounding Box Some objects are also poorly Aligned using the align tool Anybody else had this I can repeat every time here !
Thanks: 221 times Was thanked: 171 time(s) in 103 post(s)
Originally Posted by: jol Some objects are also poorly Aligned using the align tool Anybody else had this ?
Yes !
As already mentionned, text blocs are impossible to horizontal align (except if they contain the same words)...
Originally Posted by: jlm Yes ! As already mentionned, text blocs are impossible to horizontal align (except if they contain the same words)...
JL,
Can you send me an example?
Originally Posted by: Tim Olson JL, Can you send me an example? Tim
Tim,
It repeats every time :
Make a text box with "fine" & another one with "big".
Horizontal align will lift "big" with reference of the bottom of the "g" letter...
See picture of alignement of 4 blocks.
(12kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Solid Modeling
