2 Pages12>
Art
#1 Posted : Monday, September 13, 2010 7:49:35 AM(UTC)
Art
The Mesh parameters box has changed with new options. I wonder if anyone has a reliable list of STL settings that they use. I think I used to use:
Surface Deviation .0005
Normal Deviation 2.5
Edge Length 0.0
Aspect Ratio 2.5
With STL facets checked.
I seem to be getting files almost double in size with Shark 7.
Also did I read that the display settings have an effect of the mesh export?
Should I adjust nodes or use adaptive facets?
Anyway, if anyone has settings that are working well, could I get the settings?
Thanks in advance,
Art OS 10.6, Shark FX
I just started using the settings listed above and could not produce any file (4kb) went back to default and got something.
misterrogers
#2 Posted : Monday, September 13, 2010 8:33:34 AM(UTC)
misterrogers
Hi Art,
The only experience I have with rapid prototyping is with a FDM, and I always leave the STL facets unchecked. File size is almost always the same as the original. Haven't had a problem yet, and get extremely accurate results.
Art
#3 Posted : Monday, September 13, 2010 8:39:40 AM(UTC)
Art
Thanks for the reply.
These drawings are for FDM. I have always checked stl facets. I am mystified by the settings (although I know what they do). I was hoping to be able to find settings at a rapid prototyping website, but the Shark settings seem unusual.
Art
OS 10.6 Shark FX
Jean-Francois Jacques
#4 Posted : Monday, September 13, 2010 12:35:11 PM(UTC)
Canada
I do many Rapid Prototyping. Check with your RP Vendor, I send my files in ACIS-SAT and my RP Agent make is own set up for their machine.
Image-1 is my original in STL.
Image-2 is my ACIS-SAT file translated to STL by Pronto Prototyping inc.
Jean-Francois Jacques attached the following image(s):
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
NickB
#5 Posted : Monday, September 13, 2010 12:52:58 PM(UTC)
NickB
I do the same as Jean-Francois, and always send the vendor a SAT or STEP file. The vendor is then responsible for the conversion, and can tweak things for optimum results on their machine and with the material that we are using. I like to let the expert be the expert rather than messing with stuff I have little knowledge or control over - their machine / process.
Shark FX 9 build 1143
OS X 9.5
matter.cc
Art
#6 Posted : Wednesday, September 15, 2010 8:11:27 AM(UTC)
Art
Thanks for the advice. I ended up sending a step file and it went fine and much better that the troublesome stl exports. I do not know what the results will be however, since I had no control.
This makes it difficult to deal with a wide variety of vendors.
Tim, can I get some guidance?
My current products are all smaller than a breadbox. I have ruined models and money by using the default. The last document that I have on appropriate conversions is from Ashlar which was fine until the latest changes in interface.
I can't find any info on "mixed/fringe, adaptive facets and adjust nodes". I guess I don't really need to know what they are, I really need parameters. Sort of like a preset "environment". "Use this setting for a small precision part under 12" cube". Or even better "these settings are at the limit of resolution of and FDM machine" Boy, that would be great and I imagine do-able.
Are there not others in my situation?
Thanks in advance,
Art
OS 10.6 FX 7
misterrogers
#7 Posted : Wednesday, September 15, 2010 3:45:08 PM(UTC)
misterrogers
Thanks in advance,
Art
OS 10.6 FX 7
I'm going to have to second that.. I am not familiar with those terms either. The program manual that I have doesn't have an explanation for those settings - only discusses the slider settings.
Tem
#8 Posted : Wednesday, September 15, 2010 10:10:25 PM(UTC)
Tem
I had a SLA made by www.stereolithography.com
It was a first pass, turned out good for its intended purpose.
On their website are many information webpages.
Check them out.
Tem
posh.de
#9 Posted : Thursday, September 16, 2010 4:58:47 AM(UTC)
posh.de
if you wanna have control over facetting incl. a visual feedback do the meshing inside Shark by using "Edit > Change Object Type... > Mesh..." and export then.
hth,
Norbert
misterrogers
#10 Posted : Thursday, September 16, 2010 11:53:30 AM(UTC)
misterrogers
Check them out.
Tem
Thanks Tem, how fast is their shipping in the U.S.?
Tem
#11 Posted : Friday, September 17, 2010 10:33:41 PM(UTC)
Tem
Sorry for the slow response. I have been busy the past few days.
Stereolithography.com delivered in about 3 days in the US.
They communicated often, each major step was detailed enough.
If you find anyone better, please post.
Honestly, I don't remember the settings I used.
misterrogers
#12 Posted : Saturday, September 18, 2010 11:37:09 AM(UTC)
misterrogers
Hi Tem,
In the past for scaled prototypes, I've sent stuff to Shapeways. I believe they are located in Europe, though its been very easy dealing with them. Prices are reasonable, and shipping is prompt. They'll email you right away if there's a problem with geometry and usually try to fix it themselves.
#13 Posted : Sunday, September 19, 2010 2:54:24 PM(UTC)
Was thanked: 177 time(s) in 107 post(s)
Edge Length 0.0
Aspect Ratio 2.5
I seem to.
Hi Art,
I do a lot of SLAs with shark STL export.
The Hi Def Epoxy type to get maximum accuracy on small parts.
I get very good service from Ossola 3D in Italy (24 hours delivery in Paris).
My settings are usually :
Surface Deviation .002
Normal Deviation 5 for parts having smooth curves, and up to 30 for parts having plenty of tiny radius blends...
Edge Length : Default
Aspect Ratio : Default
I got this by trials and errors, and am not sure it's optimal.
Please Tim, can we get advise or tutorial ?
JLM
Art
#14 Posted : Sunday, June 5, 2011 9:44:14 PM(UTC)
Art
Sorry, I did not even know you posted until I checked tonight with the same old problems....Vendors saying my translations are lousy... I will try your settings tomorrow and look to see how my parts will come out.
Is there anybody else that makes their own STLs? I would rather have command of this stage rather than rely on vendors.
Art
Shark FX 967
OS 10.6
NickB
#15 Posted : Monday, June 6, 2011 12:33:22 AM(UTC)
NickB
Shapeways has a nice [URL="http://www.shapeways.com/tutorials/viacad"]tutorial[/URL] on using ViaCAD to create an STL, and then tuning the mesh parameters for proper STL output.
OS X 9.5
matter.cc
Art
#16 Posted : Monday, June 6, 2011 8:14:10 AM(UTC)
Art
Thanks Nick.
Do you know what "adjust nodes"
"Adaptive facets" and the mixed/fringe setting do?
Art
Shark FX
billbedford
#17 Posted : Tuesday, June 7, 2011 12:59:30 AM(UTC)
billbedford
Nothing, if you have the STL file box checked.
Art
#18 Posted : Tuesday, June 7, 2011 7:45:46 AM(UTC)
Art
Thanks, good to know I am not missing some critical feature.
Did you figure this out or is there some documentation?
Art
Shark FX 10.6
Art
#19 Posted : Tuesday, March 27, 2012 10:11:51 PM(UTC)
Art
My stl settings do not make large files like they used to. I have not changed my settings in years and yet the exports that used to be 150+ mb are now under 2mb. So my models are no usable. I know others usually use service groups to do this conversion for them, I cannot. Does anybody make fine quality stl files and have settings that they can pass on. This is only an issue I have had in the past 8 months or so. for years before that I used the same settings (the actual numbers are in my first post above).
Thanks in advance.
Art
Shark FX 7 967
10.6.8
If there is somewhere I can send the file for experiments, that is fine, I am tired of fooling with this.
la mouche
#20 Posted : Wednesday, March 28, 2012 1:29:15 AM(UTC)
la mouche
Hello,
maybe this help you
Antoine
Guest (10)
2 Pages12>
