Import/Export
Best Rapid Prototyping Settings (#3347)
The Mesh parameters box has changed with new options. I wonder if anyone has a reliable list of STL settings that they use. I think I used to use: Surface Deviation .0005 Normal Deviation 2.5 Edge Length 0.0 Aspect Ratio 2.5 With STL facets checked. I seem to be getting files almost double in size with Shark 7. Also did I read that the display settings have an effect of the mesh export? Should I adjust nodes or use adaptive facets? Anyway, if anyone has settings that are working well, could I get the settings? Thanks in advance, Art OS 10.6, Shark FX I just started using the settings listed above and could not produce any file (4kb) went back to default and got something.
Hi Art, The only experience I have with rapid prototyping is with a FDM, and I always leave the STL facets unchecked. File size is almost always the same as the original. Haven't had a problem yet, and get extremely accurate results.
Thanks for the reply. These drawings are for FDM. I have always checked stl facets. I am mystified by the settings (although I know what they do). I was hoping to be able to find settings at a rapid prototyping website, but the Shark settings seem unusual. Art OS 10.6 Shark FX
I do many Rapid Prototyping. Check with your RP Vendor, I send my files in ACIS-SAT and my RP Agent make is own set up for their machine.
Image-1 is my original in STL.
Image-2 is my ACIS-SAT file translated to STL by Pronto Prototyping inc.
Jean-Francois Jacques attached the following image(s):
(45kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
I do the same as Jean-Francois, and always send the vendor a SAT or STEP file. The vendor is then responsible for the conversion, and can tweak things for optimum results on their machine and with the material that we are using. I like to let the expert be the expert rather than messing with stuff I have little knowledge or control over - their machine / process.
Shark FX 9 build 1143
OS X 9.5
matter.cc
Thanks for the advice. I ended up sending a step file and it went fine and much better that the troublesome stl exports. I do not know what the results will be however, since I had no control. This makes it difficult to deal with a wide variety of vendors. Tim, can I get some guidance? My current products are all smaller than a breadbox. I have ruined models and money by using the default. The last document that I have on appropriate conversions is from Ashlar which was fine until the latest changes in interface. I can't find any info on "mixed/fringe, adaptive facets and adjust nodes" . I guess I don't really need to know what they are, I really need parameters. Sort of like a preset "environment". "Use this setting for a small precision part under 12" cube". Or even better "these settings are at the limit of resolution of and FDM machine" Boy, that would be great and I imagine do-able. Are there not others in my situation? Thanks in advance, Art OS 10.6 FX 7
Originally Posted by: Art Thanks for the advice. I ended up sending a step file and it went fine and much better that the troublesome stl exports. I do not know what the results will be however, since I had no control. This makes it difficult to deal with a wide variety of vendors. Tim, can I get some guidance? My current products are all smaller than a breadbox. I have ruined models and money by using the default. The last document that I have on appropriate conversions is from Ashlar which was fine until the latest changes in interface. I can't find any info on "mixed/fringe, adaptive facets and adjust nodes" . I guess I don't really need to know what they are, I really need parameters. Sort of like a preset "environment". "Use this setting for a small precision part under 12" cube". Or even better "these settings are at the limit of resolution of and FDM machine" Boy, that would be great and I imagine do-able. Are there not others in my situation? Thanks in advance, Art OS 10.6 FX 7
I'm going to have to second that.. I am not familiar with those terms either. The program manual that I have doesn't have an explanation for those settings - only discusses the slider settings.
I had a SLA made by
www.stereolithography.com It was a first pass, turned out good for its intended purpose.
On their website are many information webpages.
Check them out.
Tem
Originally Posted by: Art I do not know what the results will be however, since I had no control.
if you wanna have control over facetting incl. a visual feedback do the meshing inside Shark by using "Edit > Change Object Type... > Mesh..." and export then.
hth,
Norbert
Check them out.
Tem
Thanks Tem, how fast is their shipping in the U.S.?
Sorry for the slow response. I have been busy the past few days. Stereolithography.com delivered in about 3 days in the US. They communicated often, each major step was detailed enough. If you find anyone better, please post. Honestly, I don't remember the settings I used.
Hi Tem, In the past for scaled prototypes, I've sent stuff to Shapeways. I believe they are located in Europe, though its been very easy dealing with them. Prices are reasonable, and shipping is prompt. They'll email you right away if there's a problem with geometry and usually try to fix it themselves.
Originally Posted by: Art Surface Deviation .0005 Normal Deviation 2.5 Edge Length 0.0 Aspect Ratio 2.5 With STL facets checked. I seem to.
Hi Art,
I do a lot of SLAs with shark STL export.
The Hi Def Epoxy type to get maximum accuracy on small parts.
I get very good service from Ossola 3D in Italy (24 hours delivery in Paris).
My settings are usually :
Surface Deviation
.002 Normal Deviation
5 for parts having smooth curves, and
up to 30 for parts having plenty of tiny radius blends...
Edge Length :
Default Aspect Ratio :
Default With STL facets
checked .
I got this by trials and errors, and am not sure it's optimal.
Please Tim, can we get advise or tutorial ?
JLM
Sorry, I did not even know you posted until I checked tonight with the same old problems....Vendors saying my translations are lousy... I will try your settings tomorrow and look to see how my parts will come out. Is there anybody else that makes their own STLs? I would rather have command of this stage rather than rely on vendors. Art Shark FX 967 OS 10.6
Shapeways has a nice [URL="http://www.shapeways.com/tutorials/viacad"]tutorial[/URL] on using ViaCAD to create an STL, and then tuning the mesh parameters for proper STL output.
OS X 9.5
matter.cc
Thanks Nick. Do you know what "adjust nodes" "Adaptive facets" and the mixed/fringe setting do? Art Shark FX
Nothing, if you have the STL file box checked.
Thanks, good to know I am not missing some critical feature. Did you figure this out or is there some documentation? Thanks, Art Shark FX 10.6
My stl settings do not make large files like they used to. I have not changed my settings in years and yet the exports that used to be 150+ mb are now under 2mb. So my models are no usable. I know others usually use service groups to do this conversion for them, I cannot. Does anybody make fine quality stl files and have settings that they can pass on. This is only an issue I have had in the past 8 months or so. for years before that I used the same settings (the actual numbers are in my first post above). Thanks in advance. Art Shark FX 7 967 10.6.8 If there is somewhere I can send the file for experiments, that is fine, I am tired of fooling with this.
Import/Export
