#1 Posted : Tuesday, April 10, 2007 4:08:01 AM(UTC)
I still can't snap the endpoint of a spline to the beginning point of a spline
(except when creating it)
Snap just ignores it
Why ?
WmH
#2 Posted : Tuesday, April 10, 2007 5:00:00 AM(UTC)
WmH
Why ?
Elaborate, it seems to work for me (select end point of spline, drag it to endpoint of another spline, endpoint snap activates)
#3 Posted : Tuesday, April 10, 2007 12:54:55 PM(UTC)
I noticed that snaps are desapearing at high zoom factors.
Very often I have to zoom back and use the translate tool.
JL
#4 Posted : Tuesday, April 10, 2007 3:07:32 PM(UTC)
Wmh
draw a spline
then pick up the endpoint and try to snap it to the start point
note: only one spline
note also: this is not a problem if you connect it when you make it .. it's a problem when you connect it afterwards
WmH
#5 Posted : Tuesday, April 10, 2007 3:35:42 PM(UTC)
WmH
jol wrote:
Wmh
draw a spline
Ah, I got it; tip and tale of same spline. Yes same behavior, no snap to (any) vertex when the spline is being edited. Oddly enough the vertices do come up as constraint points. Doesn't seem to be affected by zoom
