#1 Posted : Wednesday, July 13, 2011 11:54:05 AM(UTC)
Here's a problem we've all had
Extruding - for example - a profile
A failing profile (gaps, overlaps and non-planar) - finding the problem - and fixing it - is often a pain in the ASS !
Please can we see more help / feedback / active support in correcting profiles for further processing
I suggest every failing profile should invoke a profile manager - which can report EXACTLY and GRAPHICALLY what™s wrong with the profile in question
phil
#2 Posted : Wednesday, July 13, 2011 1:18:41 PM(UTC)
phil
yes, +1 on that issue!
The gap problem is also difficult to see (the marker is kinda small and it disappears when we move/close the dialog box).
#3 Posted : Thursday, July 14, 2011 11:38:51 AM(UTC)
Was thanked: 105 time(s) in 67 post(s)
I 3rd'nd that.
I have had a number if imported meshes that were seemingly great, yet after turnign to surfaces, and turnign on the points, I could see some faces angling in, yet it took much zooming to uncover other edges not coincident. This did tell me that my original pre-imported part had some geometry with too many tight intersections or facets, and reduction of them helped. But, still...
#4 Posted : Thursday, July 14, 2011 4:41:37 PM(UTC)
overlapped and duplicate objects delete tool will be great to support this suggestion
just as rhino does
Luis G.
MacOSX Sonoma 14.7.1
billbedford
#5 Posted : Friday, July 15, 2011 1:21:30 AM(UTC)
billbedford
I've found I have much fewer problems if I invoke a work plane snap when drawing the profile.
Nick R
#6 Posted : Friday, July 15, 2011 3:00:55 AM(UTC)
Nick R
A duplicate objects tool would certainly get my vote too.
Nick
#7 Posted : Friday, July 15, 2011 4:28:40 AM(UTC)
I think there must be a whole load of checks that could be run on a profile
- look for points and very tiny lines with zero or effectively zero length (I seem to get from Illustrator imports sometimes - so small you cant see them)
- look for duplicate curves
- out of planar / tangent control is out of planar / tangent control has zero length
- mal-aligned tangents that will cause cusping and other problems down the road
- gaps - AND OFFER TO FILL with straight line, tangent continuity (G1) or curvature continuity (G2)
- offer a best guess - to fix it automagically and move on
more thoughts required
