Failed Profile should invoke Profile Manager to pinpoint issues (#3864)
Here's a problem we've all had Extruding - for example - a profile A failing profile (gaps, overlaps and non-planar) - finding the problem - and fixing it - is often a pain in the ASS ! Please can we see more help / feedback / active support in correcting profiles for further processing I suggest every failing profile should invoke a profile manager - which can report EXACTLY and GRAPHICALLY what™s wrong with the profile in question
yes, +1 on that issue! The gap problem is also difficult to see (the marker is kinda small and it disappears when we move/close the dialog box).
Thanks: 140 times Was thanked: 124 time(s) in 84 post(s)
I 3rd'nd that. I have had a number if imported meshes that were seemingly great, yet after turnign to surfaces, and turnign on the points, I could see some faces angling in, yet it took much zooming to uncover other edges not coincident. This did tell me that my original pre-imported part had some geometry with too many tight intersections or facets, and reduction of them helped. But, still...
Thanks: 39 times Was thanked: 30 time(s) in 23 post(s)
overlapped and duplicate objects delete tool will be great to support this suggestion just as rhino does Luis G.
I've found I have much fewer problems if I invoke a work plane snap when drawing the profile.
Thanks: 1 times Was thanked: 3 time(s) in 2 post(s)
A duplicate objects tool would certainly get my vote too. Nick
I think there must be a whole load of checks that could be run on a profile - look for points and very tiny lines with zero or effectively zero length (I seem to get from Illustrator imports sometimes - so small you cant see them) - look for duplicate curves - out of planar / tangent control is out of planar / tangent control has zero length - mal-aligned tangents that will cause cusping and other problems down the road - gaps - AND OFFER TO FILL with straight line, tangent continuity (G1) or curvature continuity (G2) - offer a best guess - to fix it automagically and move on more thoughts required
