object is copy mirrored when mirror no-copy was required (#3023)
copy an object using gripper (and the CTRL / option key) .. drag copy off to the right then mirror with 2 points (no option key) object is copy mirrored when mirror no-copy was required can anyone repeat ?
Thanks: 199 times Was thanked: 164 time(s) in 113 post(s)
Hi Jol, Works fine on Vista, could just be a Mac issue. Larry
Weird .. it may be because I'm running with a very full HD !? Anybody else with a Mac care to try this ?
Originally Posted by: jol copy an object using gripper (and the CTRL / option key) .. drag copy off to the right then mirror with 2 points (no option key) object is copy mirrored when mirror no-copy was required can anyone repeat ?
Jol
I get this to repeat consistently with 2d objects. Even without the gripper on. If I drag a copy of a 2d curve with gripper and ctrl. Regular mirror is always creating a copy??
thanks Jason !! It's repeating for me with 2D objects also - but only sporadically
Guys Steps to repeat Any 2d object use linked mirror to create a copy. Now any object you try to use regular mirror tool on is creating a copy without ctrl pressed. It seems linked mirror tool after using once it makes the standard mirror tool copy all objects instead of just mirror... like it is modal turning on copy mirror. If you close the program and reopen a file its ok until using linked mirror again. Regards Jason
