#1 Posted : Thursday, February 18, 2010 10:49:20 AM(UTC)
copy an object using gripper (and the CTRL / option key) .. drag copy off to the right
then mirror with 2 points (no option key)
object is copy mirrored when mirror no-copy was required
can anyone repeat ?
L. Banasky
#2 Posted : Friday, February 19, 2010 4:38:19 AM(UTC)
L. Banasky
Hi Jol,
Works fine on Vista, could just be a Mac issue.
#3 Posted : Friday, February 19, 2010 11:40:10 AM(UTC)
Weird .. it may be because I'm running with a very full HD !?
Anybody else with a Mac care to try this ?
#4 Posted : Friday, February 19, 2010 6:13:32 PM(UTC)
can anyone repeat ?
Jol
I get this to repeat consistently with 2d objects. Even without the gripper on. If I drag a copy of a 2d curve with gripper and ctrl. Regular mirror is always creating a copy??
#5 Posted : Friday, February 19, 2010 6:48:24 PM(UTC)
thanks Jason !!
It's repeating for me with 2D objects also - but only sporadically
#6 Posted : Saturday, February 20, 2010 7:55:41 PM(UTC)
Guys
Steps to repeat
Any 2d object use linked mirror to create a copy.
Now any object you try to use regular mirror tool on is creating a copy without ctrl pressed.
It seems linked mirror tool after using once it makes the standard mirror tool copy all objects instead of just mirror... like it is modal turning on copy mirror. If you close the program and reopen a file its ok until using linked mirror again.
#7 Posted : Sunday, February 21, 2010 4:24:19 AM(UTC)
Good work Jason !!
