#1 Posted : Tuesday, February 23, 2010 5:19:29 AM(UTC)
Whilst I appreciate the changes in the differential scale tool in V7 ..
.. there is an regression that's annoying me
if I click a cube 100mm x 100mm x 100mm and press enter at a scale of 2,2,2
then I get a cube of 200mm x 200mm x 200mm
so far so good
now, if I click it again and press enter - whereas in V5, the scale factor would be reapplied to the result of the first operation ... nothing now happens at all !
I must reset the tool by clicking on it again in the toolbar
worse, sometimes, if I attempt a secondary scale, the scale factors are reset to 1,1,1 and an entry is placed in the feature tree that the object has been scaled at 1,1,1 ... in other words - nothing has changed
Please, if I click with the scale tool for a second time, it's because I want to scale the object again by the factor that I specified in the topbar
ThankyooverymuchJolhasleftthebuilding
