#1 Posted : Saturday, January 22, 2011 10:44:22 AM(UTC)
Ambiguity pop-up is not dismissed with ESC key on Mac
WHY ?
It always worked on the PC - and Tim ... you promised to fix it for me !!
But despite me asking 1 million times, (Yes I counted them) ... the Ambiguity pop-up dialog box is not dismissed by the (keyboard) ESC key
This is only a problem for folk like me who used to use a PC and then moved to OSX (... otherwise, you wouldn't know the two versions don't work the same !)
Jean-Francois Jacques
#2 Posted : Monday, January 24, 2011 11:31:14 AM(UTC)
Canada
Jol, Clicking out side the Ambiguity pop-up isn't easier???
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
#3 Posted : Monday, January 24, 2011 4:59:07 PM(UTC)
Sorry all - I didn't know it worked that way !
Still, the ESC key works on PC - and is the standard way to cancel an operation ... so why not ?
#4 Posted : Friday, February 4, 2011 3:48:23 AM(UTC)
So - is there an answer please ?
If like me you switch between Mac and PC - you'll quickly see that ESC does not quit the ambiguity pop-up on Mac ... and each time you try it irritates
Are we not supposed to have feature parity here ?
#5 Posted : Friday, February 4, 2011 12:39:50 PM(UTC)
Hi Jol,
OS difference. The reason why you are seeing a difference is because it's not a behavior we programmed. The PC automatically will abort out of that type of a popup if you hit an escape key (whether you're in shark or not) where as mac does not. I'm not sure what it would take to change the behavior on mac, would need to look into further.
#6 Posted : Friday, February 4, 2011 1:38:55 PM(UTC)
Thank you Tim - now I understand
