#1 Posted : Wednesday, October 6, 2010 10:13:56 AM(UTC)
Just to be clear - here are my issues with Mac beta build 949 :
- display last image broken
- navigator is empty on startup and on app change back to Shark
- scale object for a subsequent time using the 'click, enter' method fails. Try again and the scale factors reset to 1,1,1
- some OpenGL flakiness with objects flickering off and on - sporadic can't seem to repeat
- tool icons should change to select arrow when above the drawing window topbar
- cannot nudge an object with the cursor over it (gripper on). Eg draw a cube by 3 points. Go to Select tool and leave the cursor over the cube such that it says 'origin' (or one of the gripper icons shows like the hand withe the blue arrow). Now nudge - nothing moves .. why ?
#2 Posted : Wednesday, October 6, 2010 10:38:45 AM(UTC)
and the render smudge - please can we get rid of it ?
every time I do a rendering using the "user defined" render preset, I get a graduated smudge at the top inch of my screen
interestingly, there is no smudge when using any of the other - less used and less useful presets
#3 Posted : Wednesday, October 6, 2010 10:58:31 AM(UTC)
Fixed in 950
On startup or new file is fixed in 950. Change back have not repeated yet.
Repeats here,looking into. Looks like the origin is taking the nudge.
#4 Posted : Wednesday, October 6, 2010 11:55:25 AM(UTC)
Fixed in 950.
FYI, you can also nudge gripper symbols (tx,ty,tz,rx,ry,rz,sx,sy,sz).
tx,ty,tz uses nudge distance in prefs
rx,ry,rz uses 5 degrees
sx,sy,sz scales up by nudge distance
