"Distribute" objects along line (#2946)
Is there a command/tool similar to the Linear Array tool that let's one Distribute an indicated number of objects along a line/path? I want to copy a certain # of parts along a line, but want the spacing in between to be determined automatically as a I drag the copies. I don't want to set a spacing dimension. Does that make sense? Norbert
Sort of like the "points along curve" command...it has a distribute option...
Norbert.
Wouldn't that be the Path Duplicate tool?
Martin.
(26kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Ahhhh....will give it a try.
>>Wouldn't that be the Path Duplicate tool? With V7 we also updated this tool to align wrt surface normals if you want to distribute along a surface or solid. Tim
:):):) yes Tim, finaly ;) Antoine
