2 Pages12>
norbertsf
#1 Posted : Tuesday, February 2, 2010 1:31:27 PM(UTC)
norbertsf
Is there a way to convert a closed surface into a solid in Shark?
Jean-Francois Jacques
#2 Posted : Tuesday, February 2, 2010 1:41:45 PM(UTC)
Canada
No, surfaces don't have thickness. Per example, if you extrude your surface for a minimum dimension (.001"), now you surface will be a solid.
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
norbertsf
#3 Posted : Tuesday, February 2, 2010 1:44:50 PM(UTC)
norbertsf
Jean-Francois,
I understand that, but I am more wondering if I were to create an object in another program, import it into Shark, and the imported object is a closed volume/surface. Is there a way(command) to make it a solid object?
Norbert
blowlamp
#4 Posted : Tuesday, February 2, 2010 1:46:53 PM(UTC)
blowlamp
The Stitch Solid tool should do it.
Martin.
#5 Posted : Tuesday, February 2, 2010 1:58:14 PM(UTC)
Canada
Yes, Martin with the Stitch Tool..but for a group of surfaces who make a closed volume!!
Nobert, is it your case?
blowlamp
#6 Posted : Tuesday, February 2, 2010 2:08:56 PM(UTC)
blowlamp
Jean-Francois.
Have you checked out the options?
Martin.
#7 Posted : Tuesday, February 2, 2010 2:37:57 PM(UTC)
Canada
First, martin, the answer comes from Nobert!
Any way, do you mean with disable this option "Closed Volume Required" the surface comes a solid!! .....Yes I can stitch the surface and in menu / Change Object Type... I have Solid like option.!! Strange!
#8 Posted : Tuesday, February 2, 2010 2:40:54 PM(UTC)
You can turn a surface into a "solid" that is not closed as Martin has noted by unchecking the Check Volume item.
Use this if you want to do solid modeling feature operations on surfaces such as a variable radius blend along a surface.
However, if can be a bit tricky as you need to manually adjust the direction of the surface for many solid modeling operations to work. Your surface normals need to point away from the outward material of the surface.
norbertsf
#9 Posted : Tuesday, February 2, 2010 3:05:00 PM(UTC)
norbertsf
Ok that all makes sense, but it's not working. Key thing to realize here is I want to bring an imported object into Shark to convert to solid.
As a simple test, I exported a 12" square as an .obj file.
I then imported it into Shark 5.5, and tried the Stitch tool. It gives me errors. "Invalid solid created during healing". "Could not stitch into Part". Imported obj file attached.
It should work on such a file shouldn't it?
Norbert
box-obj-import.srk (6kb) downloaded 5 time(s).
#10 Posted : Tuesday, February 2, 2010 3:23:57 PM(UTC)
That worked ok for me. I read your file in and used the defaults to stitch the facets into a solid.
norbertsf
#11 Posted : Tuesday, February 2, 2010 3:25:55 PM(UTC)
norbertsf
Tim can you list the exact steps?
Norbert
blowlamp
#12 Posted : Tuesday, February 2, 2010 3:37:45 PM(UTC)
blowlamp
Norbert
I was able to highlight the cube and do a Change Object Type into Faces, then use the Stitch tool to get a solid. I could also do a Change Object Type directly into a solid without problem.
Martin.
norbertsf
#13 Posted : Tuesday, February 2, 2010 3:42:37 PM(UTC)
norbertsf
blowlamp,
I was able to correctly make a solid via your method from the cube. But it won't work via the stitch tool...hmmm.
#14 Posted : Tuesday, February 2, 2010 3:46:35 PM(UTC)
Canada
I can stitch it!..and can change the type from the menu.
http://screencast.com/t/MzIxNTc5ZT
blowlamp
#15 Posted : Tuesday, February 2, 2010 3:50:22 PM(UTC)
blowlamp
blowlamp,
It still works ok here. Did you Change Object Type to Faces first? Perhaps reload the file and try again.
Martin.
norbertsf
#16 Posted : Tuesday, February 2, 2010 4:52:57 PM(UTC)
norbertsf
Tim,
Is turning a series of Faces into a Solid dependant on the amount of memory, or is there a face # limit?
Norbert
#17 Posted : Wednesday, February 3, 2010 10:25:14 AM(UTC)
Hi Norbert,
There is no limit, but I've found attempting to do more than 1000 facets can be hit or miss with ACIS.
It also depends on the accuracy and size of the facets. If you have small facet lengths, you many need to decrease the default maximum stitch length.
The initial model posted was facets (not surface).
#18 Posted : Wednesday, February 3, 2010 11:26:59 AM(UTC)
Hi.
Will the "thicken" tool be of any use?
(I use it to thicken surfaces, where my surfaces come from a mesh (obj or other DXF 3D type of mesh) which i stitch in groups, and then thicken variously depending on where they "steel" is located in my model.)
PRP
#19 Posted : Wednesday, September 29, 2010 10:36:07 PM(UTC)
PRP
Using Shark build 948, unable to fill skin with solid using all combinations of Change Object Type and Stitch Options.
Any suggestions?
SurfaceToSolid.sfx (62kb) downloaded 5 time(s).
PRP
#20 Posted : Thursday, September 30, 2010 10:01:54 AM(UTC)
PRP
Sorry, in my attached file the object was way off at 2:00 oclock....
Attached it's at origin, along with the one rail sweep lines that generated the object.
Do I need to close off one end somehow? Or is there a problem with the object?
Thanks Much
SurfaceToSolid a.sfx (85kb) downloaded 5 time(s).
Guest (5)
2 Pages12>
