norbertsf
#1 Posted : Thursday, January 28, 2010 9:22:46 PM(UTC)
norbertsf
I'm often moving points on curves or objects along a certain axis (x,y, or z), but then all of a sudden during the move/stretch, the cursor snaps to another point, line, object in the background. Is there a key I can hold down during this operation that temporarily disables snaps instead of going over to the "Snaps" window and unchecking things? It would be ideal if once the key is let go, the snaps come back on (until the operation is done). To get around this I usually have to zoom in and rotate so that the path of the cursor is less cluttered with possible intrusive snap areas.
Norbert
#2 Posted : Friday, January 29, 2010 4:48:50 AM(UTC)
Hi Norbert
All the individual snaps, as well as all snaps on/off can be assigned to a shortcut key, Is this what you are looking for?
norbertsf
#3 Posted : Sunday, January 31, 2010 2:10:32 PM(UTC)
norbertsf
I will give it a try
