norbertsf
#1 Posted : Tuesday, December 29, 2009 5:21:52 PM(UTC)
norbertsf
So I need to model a solid flame. I made quick surface model in Cinema4D, but this will not do for casting.
Can such a shape be made in Shark? In C4D I basically moved areas of polygons with a weight/magnet tool. This was about 1 hours worth of work.
I'm going to give it a go soon, but wanted some input on what the best direction might be.
Norbert
UserPostedImage
Steve.M
#2 Posted : Tuesday, December 29, 2009 5:35:36 PM(UTC)
Steve.M
Hi Norbert,
What are you using for this? 2d-3d/Pro or Shark.
- Steve
norbertsf
#3 Posted : Tuesday, December 29, 2009 5:39:57 PM(UTC)
norbertsf
Will be using Shark 5
Steve.M
#4 Posted : Tuesday, December 29, 2009 5:50:12 PM(UTC)
Steve.M
OK,
I will have a play in pro.
For the first attempt, I am thinking:-
I will create the top/bottom of a single flame, then loft solid between them to get the flow, make more (or use copies of the first with possible scaling) then joint them with blending.
zumer
#5 Posted : Monday, January 4, 2010 12:46:11 AM(UTC)
zumer
It's possible with deform face to point. The tool can be flakey, but it comes up with very organic shapes.
