norbertsf
#1 Posted : Thursday, May 24, 2007 4:10:45 PM(UTC)
norbertsf
I'm having an issue where ViaCAD's snaps are snapping correctly (endpoint ,midpoint etc.) but the cursor is actually NOT snapping on the part VISUALLY. Almost as if it is snapping to a 1/2" offset ghost/hidden 3d part (of which there is none). Is this a bug? Quitting and restarting the program does not help.
Make sense?
http://img452.imageshack.us/my.php?image=snapsrc0.jpg
Norbert
NickB
#2 Posted : Thursday, May 24, 2007 6:07:56 PM(UTC)
NickB
Looks like you are trying to build with perspective on.
CU / ViaCad is completely broken when it comes to doing anything other than looking at a model in perspective mode.
Turn perspective off, and you should find everything works fine.
Shark FX 9 build 1143
OS X 9.5
matter.cc
#3 Posted : Thursday, May 24, 2007 11:31:37 PM(UTC)
Yes, it looks like a perspective issue. I was trading notes with our home design team at Punch who ran into a similiar problem and found a slick solution which we hope to implement in an upcoming version.
Punch! Software
#4 Posted : Friday, May 25, 2007 4:56:48 PM(UTC)
I hope it's not too far away .. we've put up with this for 7 or 8 years
If you cant use the drafting assistant in Perspective mode .. don't show it !! Turn it off .. that way your software won't look broken !
It's confusing and incorrect
