Background image? (#432)
I am thinking about buying viacad after playing with the concepts 3d demo but I have a question. Is it possible to bring in a set of background images to model from? What I mean is a set of images for each view. Front Side Back top etc. I have scratched my head trying to work out if it is possible myself. Other than that I am liking it very much although finding things can be a bit of a nightmare while I am not used to it. Cheers Mike R
Hi Mike, >>I sure hope jpg is usable in viacad. Currently BMP. I hope we can expand additional raster formats in a future version. >>Also how about an option so that the viewport doesn't roll about all over the place. Could you explain further? FYI, I'm looking into some improvemnts for raster image support for the products, including the ability to set a transparent color. If anyone has some suggestions, now is a good time to provide some feedback.
mykyl1966 wrote: Hi Mike, FYI, I'm looking into some improvemnts for raster image support for the products, including the ability to set a transparent color. If anyone has some suggestions, now is a good time to provide some feedback.
I would suggest jpeg and tif for additional file formats and when placing images, have the image auto-center to 0-0 instead of coming in with the zero point at the upper left. That would make it easier to bring in images and start modeling, as opposed to having to manually center the image in each viewport.
Regarding the rolling about all over the place. Currently the viewport can be banked left and right which I find unnatural. It resembles the viewport of a flight simulator game, where you can turn left right up and down as well as bank over to the left or right. I prefer the viewport to be more like an fps game, where you can turn left and right and up and down but not bank. Looking from a front view the 'floor' plane or x should always be level. In other words remove the rotate around the y. If this was an option not exclusive then it would help a lot of people and not just myself. I hope the above makes sense. If not just ask and I will capture some screens to explain what I mean. While I am at it, the ability to export obj files in the way moi3d can do would be perfect. They allow the option to export all tris or tris and quads or N-gons. N-gons are more useful to me. They also supply a movable arrow to select more or less polygons. Fantastic stuff. Download the beta while its available to see what I mean. Cheers Mike R
>>I prefer the viewport to be more like an fps game, where you can turn >>left and right and up and down but not bank. Looking from a front view >>the 'floor' plane or x should always be level. In other words remove the >>rotate around the y. What if we were to lock the rotation axis when dynamically rotating by hitting the x, y, or z keys? >>the ability to export obj files in the way moi3d can do would be perfect. We're exploring OBJ import/export to an upcoming product which includes vertices, normals, color, and texture coordinates, but just triangles at this time. When I get a chance, I'll take a look at moi3d.
I think your suggestion to lock the rotation is a possibility that could work. The reason why I asked you to look at Moi3d is the N-gons export is very good and any possible glitches can easily be counteracted with a quick extra bevel in Modo. (Modo is my render engine of choice.) Either way, I am excited by the possibilities with your software and look forward to ordering it soon. Cheers Mike R
