Rendering & Display
How do I get rid of that blocky feeling? (#3472)
Below is a picture of that blocky feeling... notice the lug nuts are little blocks...
After a while they finally look like lug nuts again...
How do I make that happen faster?
I'm running on a quad-core laptop with ATI Radeon HD 4650 graphics.
Mike...
(43kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Hi Mike
View Shade options
Dynamic level of detail lower is more detail.
(11kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
so if I set it to 0 will I always have full detail? Mike...
I generally set it to 1.0 or 1.5. 1.0 is the default for static detail so why set it lower than (finer) than you can display ? Unfortunately, at least on a Mac the setting needs to be re-set ever time that you launch Shark as it is not saved with the file, and there does not appear to be any way to set it as a global preference. Either this is a bug, or an oversight.
Shark FX 9 build 1143
OS X 9.5
matter.cc
Thanks: 2 times Was thanked: 29 time(s) in 21 post(s)
Nick, On your PC your value stay like the default? Like you said not on the Mac. I ask to Tim for a long time that is a problem!!
Rendering & Display
