mikeschn
#1 Posted : Saturday, September 20, 2008 2:59:45 PM(UTC)
mikeschn
Is there a way to rotate the work plane by some angle, like 15?
The dialog that pops up when I select modify work plane requires a mathematician to manipulate.
Mike...
#2 Posted : Saturday, September 20, 2008 3:38:41 PM(UTC)
True Mike, graduated in general relativity !
mikeschn
#3 Posted : Sunday, September 21, 2008 12:16:17 PM(UTC)
mikeschn
Here's the interface I am used to. Maybe Tim and crew can use something similar.
UserPostedImage
Mike...
Steve.M
#4 Posted : Tuesday, September 23, 2008 7:24:07 PM(UTC)
Steve.M
Hi Mike,
The "modify work plane", you can input using the cursor snapping to construction lines or predefined snap angles, you do not need to enter numbers directly into the popup.
- Steve
#5 Posted : Wednesday, September 24, 2008 12:43:21 AM(UTC)
The 'c' key allows simple work plane cycling
Perhaps option + c (Ctrl c) could give a simple dialog with more help for choosing various orientations
