Solid Modeling
rotate the work plane by some angle (#1653)
Is there a way to rotate the work plane by some angle, like 15? The dialog that pops up when I select modify work plane requires a mathematician to manipulate. Mike...
Thanks: 224 times Was thanked: 173 time(s) in 105 post(s)
Originally Posted by: mikeschn The dialog that pops up when I select modify work plane requires a mathematician
True Mike, graduated in general relativity !
Here's the interface I am used to. Maybe Tim and crew can use something similar.
Mike...
Hi Mike, The "modify work plane", you can input using the cursor snapping to construction lines or predefined snap angles, you do not need to enter numbers directly into the popup. - Steve
The 'c' key allows simple work plane cycling Perhaps option + c (Ctrl c) could give a simple dialog with more help for choosing various orientations
Solid Modeling
