Hello,
This seems really basic, but I seem to be missing some of the key operations here.
I'm trying to reproduce the jpg to a 3d element to cut out on a cnc.
Particularly the axe head . I just can't seem to figure out how to get this done.
I need some pointers on how to draw this one out.
A video tutorial on how to get this done would be great! :)
thanks!
ht.vcp
(1,048kb) downloaded 0 time(s). Mogal attached the following image(s):
(35kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
I suggest starting with creating an extrusion shape from the direction that is normal to the handle hole. Next, create a radial cut by creating a radius with a center offset from your part behind the square side, that will define the cutting blade edge. finally make 2 shapes for the side cuts (top and bottom side profiles). Its really simple, I think. Good luck!
Bobcad has a feature in BobArt where you can take a .jpg and emboss the thing without drawing a thing.
