Import/Export
Export to jpg/bmp Shows Select Lines (#2035)
                Every time I try and export my design as an image, whether a jpg or a bmp, the exported image shows up with all select lines visible.  In other words, there are red select lines everywhere.
So far, the only way around it is to do a screen capture using Ctrl-Alt-Prnt Scrn.
Is this a bug with the program or is there a way to correct this issue?
mlochala attached the following image(s):
(106kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                If items are selected - then they'll show with red
                Here's a bug on the Mac
Save a .jpg on top of a file that already exists
see 'getinfo' image and note difference between the icon preview at the top and the correct icon preview beneath
ie : it's not overwriting the file's preview icon .. as seen in the finder and in 'getinfo'
(24kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                Originally Posted by: jol  If items are selected - then they'll show with red
jol, when I do the export to .jpg, I make sure nothing is selected.  This isn't an issue with any single file, either.  This happens with all of them.  Somehow during the process of exporting the image to .jpg it is selecting everything and that's how I'm getting the red lines.
Surely someone else has had this issue.
                Sorry - I misunderstood
Import/Export
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
