Art
#1 Posted : Wednesday, June 4, 2008 2:44:12 PM(UTC)
Art
On my desktop computer I lost the shaded view when I used the trackball for rotation (I never lost it on the dynamic rotate tool). I assumed it was some preferences gone or something, tech support could not help, and I learned to live with it.
I just installed Shark on a laptop and have the same problem, fresh install.
Do others have this problem? Perhaps only with the latest version? (738?)
Art
MacIntel/Shark
nick
#2 Posted : Wednesday, June 4, 2008 4:00:18 PM(UTC)
nick
Hello Art
Doesn't repeat for me, which graphics boards do you have in your desktop and laptop?
All the best
Nick
Art
#3 Posted : Wednesday, June 4, 2008 5:25:03 PM(UTC)
Art
Hi Nick,
Thanks for responding. On my desktop I have the ATI Radeon X1900XT with 512 VRAM. On the laptop I have the Nvidia GeForce 8600M GT with 256 VRAM.
On the laptop I have not changed from the original setup, I just installed it yesterday.
Do you think this might be the problem?
Art
MacIntel/Shark
#4 Posted : Wednesday, June 4, 2008 5:37:12 PM(UTC)
Art,
I will make a Shark patch tonight using the current V5 code (748) and let's see that fixes it.
ttrw
#5 Posted : Wednesday, June 4, 2008 5:42:14 PM(UTC)
ttrw
Hey Art, I tried it on my MBPro with both Shark FX and ViaCAD, and like Nick, I'm not seeing it either. Can you send in an apple-shift-4 screenshot? As this may help us deduce what's going on? Cheers.
nick
#6 Posted : Wednesday, June 4, 2008 5:44:57 PM(UTC)
nick
Hello Art
Strange I'm not seeing the same result, I also have Nvidia 8600M GT but with 512Mb RAM. Are you running 10.5.3?
All the best
Nick
Art
#7 Posted : Wednesday, June 4, 2008 8:33:19 PM(UTC)
Art
Guys,
Thank you for all the quick replies. Now I realize that perhaps it was a deliberate change.
I always work in wireframe and would use the trackball to get a view of how things are going together because it would give me a flat rendering when I rotated the object.
Now you can use the dynamic rotate tool in that way; work in wireframe, when you move it it gains surfaces, when you stop it goes back to wireframe. The trackball used to work like that. The trackball was a "dynamic shade" now it is a "static" shade.
As I am writing this it seems like a subtle interface change, perhaps I am the only one that appreciated the old way.
Best,
Art
Shark FXScreenSnapz001.zip (316kb) downloaded 5 time(s).
Art attached the following image(s):
Picture 1.png (36kb) downloaded 5 time(s).
nick
#8 Posted : Thursday, June 5, 2008 8:16:10 AM(UTC)
nick
Hello Art
I don't think it's your perception that's incorrect, I think it's a bug when you use the constant rotate mode of the viewball as I get exactly the same behaviour. However, when using the viewball in regular rotate mode the model is shaded upon rotation just as per dynamic rotate tool. Sorry for confusion, initially I thought you were just using the viewball in regular rotate mode.
Over to you Tim ;-)
All the best
Nick
#9 Posted : Thursday, June 5, 2008 9:21:15 AM(UTC)
If understand correctly, what is wrong is the spin mode for stepper should be using the dynamic display mode.
Art, if you want a quick phong rendered visual, you could assign a short cut to render now.
BTW, I put up a 747 Shark build for you.
Art
#10 Posted : Thursday, June 5, 2008 9:46:20 AM(UTC)
Art
Yes
OK
Thanks, but I can't get the link to work.
Art
MacIntel Shark
