When I use the "Deep Select" cursor to explode a curve on a solid in a group it does not work. When I try to offset a face of a solid within a group, it does not work. Is it supposed to? If not, what is it good for? Art MacIntel/Shark
>> Is it supposed to? No, but those tools should be corrected to recognize edges/faces within groups independent of deep select. >>If not, what is it good for? We orginally put it in to select objects within groups. We're gradually extending its functionality. Things that deep select can do --modify objects position/attributes within a group --automtically turns on/off points &handles for splines --pick faces of a solid and change color --pick faces of a solid and remove them by hitting the delete key Tim
