misterrogers
#1 Posted : Thursday, July 8, 2010 10:16:52 AM(UTC)
misterrogers
I have experimented a little with the Attributes/BOM box, but I'm still trying to figure out how to have custom headings and fields.
The current headings and fields are fine, but I couldn't find one that had dimensions of L/W/H and then calculates cubic meters.
Fields I need:
-No. of part i.e. 1,2,3...
-Qty of Part Needed
-Part Name/Description
-Quality of Mat'l
-Dimensions L x W x H
-Total Area of Part (cubic units)
Did I miss this in the fields? How can I customize this feature to reflect my requirements? I've been using excel and feel that it would be better/easier to do all of this within Shark itself.
I searched the forum and found an old (2007) tutorial from Tim but it didn't seem to show anything in the way of customizing headings.
Thanks!!
#2 Posted : Thursday, July 8, 2010 12:50:38 PM(UTC)
Was thanked: 102 time(s) in 66 post(s)
Also, would you check to see whether any BOM Part ID changes when the drawing is edited? I wish that a master number could be fixed to at least one piece of original geometry (as if the the parent DNA) so that anything added to the initial pieces has a master number. Any subsequent changes would not alter the original number.
Also, it would be nice if a user field allowing ad-hoc naming or layer info could be part of the BOM. Last i looked i felt i couldn't do some things i'd been asking for, then forgot because i had ohter fish to fry.
#3 Posted : Friday, July 9, 2010 11:49:49 AM(UTC)
How about attached? Put this file in your BOM folder.
ExtentsVolume.bom.zip (1kb) downloaded 0 time(s).
misterrogers
#4 Posted : Friday, July 9, 2010 6:32:11 PM(UTC)
misterrogers
This is perfect! Thanks Tim.
