misterrogers
#1 Posted : Thursday, September 16, 2010 7:26:00 AM(UTC)
misterrogers
Is there some sort of trick to this tool? I'm trying my darndest to hatch in a section and I can't because it keeps saying "no valid hatch region found".
Please tell me what I'm doing wrong. I've got a conic attached to a line and it's closed and still no hatch region...?? This happens all too frequently.
The line is just a segment with beginning and end points at the conic's beginning and end.
Stymied.
misterrogers attached the following image(s):
#2 Posted : Tuesday, September 21, 2010 11:45:04 AM(UTC)
Make sure the curves you are hatching are all on the screen.
There is also the option to select the curves using the option/control key. This by passes the autodetect which curves to hatch logic of the command.
la mouche
#3 Posted : Wednesday, September 22, 2010 1:38:44 AM(UTC)
la mouche
and also verify that the curves are in the: same plane :)
Antoine
misterrogers
#4 Posted : Wednesday, September 22, 2010 12:24:31 PM(UTC)
misterrogers
Thanks Tim and Antoine!
#5 Posted : Thursday, September 23, 2010 10:13:40 AM(UTC)
I also did some work in 949 regarding hatching that should make it more robust based on some issues reported from tech support.
