misterrogers
#1 Posted : Tuesday, August 24, 2010 2:18:08 PM(UTC)
misterrogers
What do any of you guys use for your sheet metal work?
#2 Posted : Thursday, August 26, 2010 7:12:42 PM(UTC)
Mexico
what i use most is the 2d profiling part, and export to a DXF that is imported for cutting on my machines
i been finding ways to send a dxf to plasma and water jet cut, controlling the led int an led out and the the sequence of the cut, little tricky but can be done,
i also build the 3d models on shark, with some cares you made model that can be easily converted to a a sheet metal part on solid works
i prefer the modeling tools on shark
a simple surface flattening tool has been requested many times in this forum, no luck yet
Luis G.,
MacOSX Sequoia 15.7.7
misterrogers
#3 Posted : Thursday, August 26, 2010 9:10:40 PM(UTC)
misterrogers
Luis G.,
When you speak of this "surface flattening tool" do you mean something that allows a 3D part to be instantly shown as "flat"? If not can you please give an example?
#4 Posted : Sunday, August 29, 2010 1:39:38 PM(UTC)
Mexico
A tool for develop a curved surface into its flat pattern, a good sample is the smash surface tool and the unroll developable surface tool on rhino, like a cone or cylinder with an intersected solid o hole on it.
here other threads with same or similar request
http://forum.punchcad.com/showthread.php?t=2828
http://forum.punchcad.com/showthread.php?t=325
See the sample, the flat surfaces was unfolded with rhino
Luis G.
[ATTACH]3471[/ATTACH]
unrol-flatten.sfx (65kb) downloaded 5 time(s).
misterrogers
#5 Posted : Tuesday, December 7, 2010 8:23:20 PM(UTC)
misterrogers
I know this thread is a few months old, but I just noticed that Turbocad Pro 17 has Unbend and Unfold Face tools for flattening objects.
Could this be a possibility someday in an future Shark release?
#6 Posted : Tuesday, December 14, 2010 1:41:46 PM(UTC)
Mexico
Could this be a possibility someday in an future Shark release?[/QUOTE wrote:
I Really second this, please Tim don you remember this promise?:
http://forum.punchcad.com/showpost.php?p=4890&postcount=7
misterrogers
#7 Posted : Thursday, December 16, 2010 7:33:39 PM(UTC)
misterrogers
Wow that was in 2008. I hope it materializes someday.
#8 Posted : Thursday, June 30, 2011 3:10:20 PM(UTC)
Mexico
Just to remember again this promise
Luis G.
