misterrogers
#1 Posted : Saturday, December 4, 2010 1:01:25 PM(UTC)
misterrogers
I know that repeatedly hitting "C" over an axis or point is for cycling-through/setting an arbitrary plane, but how do you VIEW from that arbitrary plane?
blowlamp
#2 Posted : Saturday, December 4, 2010 1:08:45 PM(UTC)
blowlamp
Is Menu -> View -> View The Plane, what you need?
Martin.
mikeschn
#3 Posted : Saturday, December 4, 2010 1:28:55 PM(UTC)
mikeschn
If that is indeed the command you were looking for, I have another thought for you...
Assign it to a hot key, like z.
I did that and found myself using the z key more than you can imagine. So much so that I went to work and assigned the z key to view the plane on all the cad programs that I use!
I'm Z happy!
Mike...
NickB
#4 Posted : Saturday, December 4, 2010 4:50:26 PM(UTC)
NickB
Or . . .
press the A, S or D keys to view the default side, top and front views.
Shark FX 9 build 1143
OS X 9.5
matter.cc
misterrogers
#5 Posted : Sunday, December 5, 2010 9:11:35 AM(UTC)
misterrogers
Hahah Thanks guys! the View > View the Plane was hidden from sight for me. It magically disappeared from my absent-minded eyes. And somehow it magically re-appeared.
I kept looking under the Work Plane menu.
Speaking of shortcuts, I will say that I do use Z but it's currently assigned to Corner-to-Corner Square. My Q is a straight line, and A is straight line from midpoint. X is segment-at-location. R is rotate, T is translate, O is convert object, E is explorer, I is eye-dropper, M is measure (maybe that was a default), P is point, S is select mask, W is mirror (since the letter looks like a mirrored object), and so on.
Since i start all my modeling from 2d cad, I find that these few short cuts speed up my work flow tremendously. Some of my peers still love autocad and mainly because of it's command line which I don't care for.
Guest (5)
