Rendering & Display
Size when Rendering to File? (#3065)
I'm not sure what to set the resolution to when I'm rendering to file? For example, if I'm printing something that is going to fit on a letter size paper (8.5x11"), what's a good resolution to write in the two fields? Thanks!
Thanks: 23 times Was thanked: 49 time(s) in 36 post(s)
Originally Posted by: misterrogers I...if I'm printing something that is going to fit on a letter size paper (8.5x11"), what's a good resolution to write in the two fields?
length [inch] x resolution [dots per inch] = 8.5" x 300dpi = 2,550 dots (= pixel)
the resolution depends on your output device, for e.g. laser printers 150-200dpi are regularly good enough.
be aware, that [URL="http://web.forret.com/tools/megapixel.asp"]file size does not increase linear but quadratic[/URL].
hth,
Norbert
I was about to ask what Quadratic meant and then I clicked on the link...thanks for posting that. I love knowledge, even when I don't understand it.
Brian Graham Mac OS Ventura 13.6.3 Mac mini Apple M1 16GB 1TB SSD Shark FXv 14 Build 1641
Originally Posted by: posh.de length [inch] x resolution [dots per inch] = 8.5" x 300dpi = 2,550 dots (= pixel) the resolution depends on your output device, for e.g. laser printers 150-200dpi are regularly good enough. be aware, that [URL="http://web.forret.com/tools/megapixel.asp"]file size does not increase linear but quadratic[/URL]. hth, Norbert
Thanks Norbert! didn't realize there was such a simple formula to figure it out. I keep forgetting that computers are so much more intelligent than me.
Originally Posted by: grahamdesign ...even when I don't understand it.
hth,
Norbert
Rendering & Display
