Rendering & Display
Size when Rendering to File? (#3065)
                I'm not sure what to set the resolution to when I'm rendering to file?  For example, if I'm printing something that is going to fit on a letter size paper (8.5x11"), what's a good resolution to write in the two fields?  Thanks!
                Originally Posted by: misterrogers  I...if I'm printing something that is going to fit on a letter size paper (8.5x11"), what's a good resolution to write in the two fields?
length [inch] x resolution [dots per inch] = 8.5" x 300dpi = 2,550 dots (= pixel)
the resolution depends on your output device, for e.g. laser printers 150-200dpi are regularly good enough.
be aware, that [URL="http://web.forret.com/tools/megapixel.asp"]file size does not increase linear but quadratic[/URL].
hth,
Norbert
                I was about to ask what Quadratic meant and then I clicked on the link...thanks for posting that. I love knowledge, even when I don't understand it.
    Brian Graham  Mac OS Sequoia 15.4.1  Mac mini 2024 Apple M4  24GB  1TB SSD  Shark FXv 15 Build 1722
                Originally Posted by: posh.de  length [inch] x resolution [dots per inch] = 8.5" x 300dpi = 2,550 dots (= pixel) the resolution depends on your output device, for e.g. laser printers 150-200dpi are regularly good enough. be aware, that [URL="http://web.forret.com/tools/megapixel.asp"]file size does not increase linear but quadratic[/URL]. hth, Norbert
Thanks Norbert!  didn't realize there was such a simple formula to figure it out.  I keep forgetting that computers are so much more intelligent than me.
                Originally Posted by: grahamdesign  ...even when I don't understand it.
hth,
Norbert
Rendering & Display
