Punch Lounge
dowels - metal vs wood (#4207)
Can anyone please explain what the benefits of using Metal dowels are over wood? Metal doesn't require glue (at least in furniture) and is stronger, but what applications would metal be of more value?
Thanks: 186 times Was thanked: 159 time(s) in 109 post(s)
My experience with metal dowels are with metal applications only. Dowels, or dowel pins, as they are usually called, help in locating machine parts that are sometimes diassembled, such as a punch and die set, or gearbox cover. The dowels, usually 2 or more, assist in assembling the parts in the same location, as before disassembly. The bolt holes for the bolts that hold a gear cover on are usually not a precise fit, but the dowel holes and dowel pins are a very precise fit, sometimes requiring a tap in with a hammer. Hope this helps. Larry
Larry's right. In engineering, metal dowels are strong, repeatable location elements, usually light-but-tight fits. Quite often, they're tubular or roll pins coaxial with, and around bolts, so they don't need accomodation in their own bosses where mass of material matters. Wooden dowels are concealed fasteners as well as interference-fit locators in woodworking, glue mandates one-use-only, but they increase glue contact area. murray
Thanks for the explanation both of you. I understand better now they're used for repeated assembly/disassembly whereas wood dowels won't quite offer the same quality over and over. I've noticed that on lower-end 3-in-1 and 4-in-1 cribs the sides are fastened with hex-driven connecting bolts but located with metal pins and never wood. Since the cribs are meant to be configured differently over the baby's early years that makes sense to do.
Punch Lounge
