Solid Modeling
Constraining Movement in Shark? (#4474)
Can I constrain movement of a part? e.g. Drawers only able to move in one axis? Thank you.
You can lock a part from being touched so no movement at all. Your goal to restrain only to one axis I don't think is doable. Just use the gripper to restrain to any axis.
Thanks, but does that mean I cannot create an assembly where a part is constrained to not pivot more than a certain degree?
If you are talking about animation, you can constraint motion in any linear axis or any rotational axis. Even in rotational degrees. For the sake of moving a part out of the way, you can use the gripper or the move command while in any plane view.
rockyroad that is exactly what I meant - animating while constraining the motion. I should have said animation - thanks!
Solid Modeling
