2D Drafting
Centerlines not showing up (#4436)
Since upgrading to Shark v8, the hole-centerlines never show up anymore even if Pen Styles (Holes) is set to Visible or other line style.
Also don't show up even when Hole Centerlines is checked.
Having to put them in manually each time is now a painstaking process.
Is there a setting I've got wrong somewhere?
It's like my holes (made by the hole-tool) aren't recognized as holes.
*And I know the line style isn't just black and being hidden by the black background - because the centerline style is blue.
misterrogers attached the following image(s):
(88kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Hi, has anyone else experienced this problem?
Can you provide a small example file? I fixed a problem in 1013 where some lines were removed that should have been visible. Does this happen in 1013 as well? Tim
Tim, please see the attached file - I am using Shark FX v8 build 1005 - maybe that's the problem. If so please share the link to the newest build please.
Sometimes the center-lines are there and then they all disappear after I click-drag a new view from it.
Thank you.
centerline problem.sfx
(932kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Checking...
Build 1013 is looking pretty good. You can download from the labs at..
http://punchcadlabs.com/page12/page12.php Tim
Ok I think I've got this fixed in the next upload. A small tolerance issue.
I've attached the file when regened in the latest build. Holler if this is what you were expecting.
Many thanks for posting that file!
centerline.sfx
(561kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Tim – thank you. That is exactly what I was expecting. Thought I was going crazy but glad there was a real issue that is now fixed. I will gladly d/l the next build when it is available. And while you're paying attention to me, please see my wish list for Shark v9 : [SIZE="6"]1. Parts/Assemblies 2. 3D Mating/Constraints to Planes [/SIZE] Just think of how many people will be happy! That is all.
2D Drafting
