BridgeCityMike
#1 Posted : Monday, May 23, 2011 1:12:09 PM(UTC)
BridgeCityMike
I don't think there is a way to currently do this...correct me if I am wrong.
Can there be a way to align the parts in mulitple viewports easily? I tend to move my viewports around to make room for dimensions, but I like to have my drawings line up like in true orthographic style. It is quite slow to manually re-align.
Also, do other people have issues when moving the viewports? Does it sometimes move when you merely want to only adjust the size?
#2 Posted : Monday, May 23, 2011 4:15:48 PM(UTC)
Hi Mike
Did you try the align in the rt click menu? Activate draw view rt click in upper left corner small box.
Do you mean when you activate the draw view and hover your mouse over the control points at top, btm, rt and left center points and corners they will move the draw view vs make bigger? If you miss the control point of draw view it will move vs make bigger.
BridgeCityMike
#3 Posted : Tuesday, May 24, 2011 12:12:00 PM(UTC)
BridgeCityMike
Aha! Thanks for that tip! I've been searching for that align tool!
I just did a test again. The viewport movement happens when I am adjusting the viewport only a tiny bit. If I enlarge the viewport by a large amount it is fine, but to just do it 1/16th increments and the drawing moves.
Thanks for you help!
