workshopswarf
#1 Posted : Monday, May 6, 2013 10:58:41 AM(UTC)
workshopswarf
I have an object with a hole, I want another without the hole. I can copy the object but how do I remove the hole?
I am using 2D3D v7
Thanks for any help.
Jean-Francois Jacques
#2 Posted : Monday, May 6, 2013 12:19:47 PM(UTC)
Canada
Right Click - Duplicate Part History...but maybe you will loose some history part in the original object??
http://screencast.com/t/f900US2Jc6c
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
workshopswarf
#3 Posted : Monday, May 6, 2013 12:45:26 PM(UTC)
workshopswarf
I right click and select duplicate with history, then what? Nothing happens.
I can drag off the new part, still with hole.
zumer
#4 Posted : Monday, May 6, 2013 4:24:27 PM(UTC)
zumer
Select the part and bring up concept explorer, suppress or remove the hole feature in it, or select the hole's faces and remove them (defeature) in face utilities.
workshopswarf
#5 Posted : Tuesday, May 7, 2013 9:02:27 AM(UTC)
workshopswarf
Thanks for the guidance. I don't seem to be able to get to the feature or suppression options.
I click on the object, bring up concept explorer, click the + sign next to the part name and only "ACIS solid 59850" is displayed in the tree. Right click on that gives option to rename, inspector attributes and force resolve links.
EDIT
I have tried again from Duplicate part history and all is well. Thanks for the help.
Sorry for the basic question.
zumer
#6 Posted : Wednesday, May 8, 2013 4:00:31 AM(UTC)
zumer
Sounds like you've inadvertantly dumped the history of the original. Might be useful to copy the copy with history to reconstitute it - and check that the history of the first copy hasn't gone AWOL, too. Don't apologise for asking questions, that's how everyone learns.
jb2953
#7 Posted : Wednesday, May 8, 2013 6:23:28 AM(UTC)
jb2953
To remove a hole I go to the thicken tool and thicken the material in the hole half the diameter of the hole.
Jim
memphisjed
#8 Posted : Saturday, June 29, 2013 12:17:38 AM(UTC)
memphisjed
jimb that sounds brilliant. I have tried matching surfaces and adding them, but never looks clean.
#9 Posted : Tuesday, July 2, 2013 2:31:04 PM(UTC)
Mexico
mmmh... 2d-3d v7 doesn't have remove face tool?, its quicker to remove faces from solid
Luis G.
MacOSX Sequoia 15.7.7
jb2953
#10 Posted : Tuesday, July 2, 2013 8:47:48 PM(UTC)
jb2953
Luis I never would of thought of using remove face for a hole. You learn something new every day
