is Skin Surface working correctly (#4998)
Thanks: 3 times Was thanked: 4 time(s) in 3 post(s)
I do have a problem with skin surface depending where i start i get a different skin see pics. Pic 1 i started from the smaller object to the bigger and the skin did not take all (both lines are grouped). Pic2 i did start from the longer object to the smaller. Now on the other side skin is missing. I did redraw the whole drawing now the third time :mad::mad: getting always the same problem. Can someone please help. thanks
regards
Martin
test.vcp
(180kb) downloaded 0 time(s). martinwh99 attached the following image(s):
(51kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
Martin Krueger ViaCAD Pro V12 PowerPacked, Cut2D, Cut3D _myMill self made CNC milling-machine
It appears that you need to join the curves that are adjacent to each other, not grouping them.
