Problem with Mass Calculation In ViaCAD Pro (#4669)
Hi, I've found that the mass properties calculations are not scaling correctly with units. For example if I take a flat aluminum disk 1" in diameter by .25" thick and look at the calculated Weight in the Vew Properties menu, it does not change if I display in grams or kg (using the check box). It seems to use the density based on kg/cm3 no matter what the state of the check box. That is, it displays a density of .003 Kg/cm3 and .003 g/cm3 for each units set. I notice that if you have the use grams check box enabled and select a new material from the drop down menu, the density displays correctly (2.7 g/cm3 for aluminum) but the calculation uses Kg/cm3. Is this a known bug? Will it be fixed in an update? Thanks in advance for any help. Mark
Thanks: 224 times Was thanked: 173 time(s) in 105 post(s)
Thank you Mark to mention this bug. I've made several posts about it (on Shark too). As you give more details than I did, it may be fixed soon... JL
I contacted the developers about this very problem They have fixed it in the code Not sure what that means for updates
