Surface Modeling
3D Scan Data to CAD Model (#990)
Thanks: 1 times Was thanked: 4 time(s) in 4 post(s)
Here is an interesting piece of software making possible to convert 3D Scan data (stl/obj) into editable CAD model.
It is called ScanStudio Pro.
Go to this website:
https://www.nextengine.com/indexSecure.htm click on products then ScanStudio Pro and see included video demonstration.
Can this be done with all the tools we have in Shark???
Intel iMac-20,2 | macOS Ventura 13.3.1 | SharkCAD 14 |
Very interesting Mark.
If they had a Mac version, I would buy it straight away...
JL
I have the next engine scanner. I used the stl file to reproduce a shape in Concepts (shark 4)
I'll put the images in the gallery this week. After scanning the data the mesh did not seem usable enough to make a model. They were a good reference though.
The solidworks demo of similar software (probably the same) is very compelling.
http://www.solidworks.com/pages.../solutions/ScanTo3D.html However demos always seem easy compared to actual use.
JL if you have an intel mac then a pc is only a reboot away with boot camp!
Mark L.
lebeau wrote: I have the next engine scanner. I used the stl file to reproduce a shape in Concepts (shark 4)
Mark L.
I'm pretty sure that Solidworks (Office Premium only) uses it own Scan to 3D software to create the model. Next Engine most likely only provides a seamless delivery to Solidworks.
tom
If it actually work like that... It would be very cost effective if the transfer to Shark was seamless and accurate. Patrick
lebeau wrote: I have the next engine scanner. I used the stl file to reproduce a shape in Concepts (shark 4) I'll put the images in the gallery this week. After scanning the data the mesh did not seem usable enough to make a model. They were a good reference though.
lebeau,
What is your method for turning scanned organic shapes into CAD Models.
Mark
I was not really able to use the organic surfaces. I used the scanned file as reference geometry. I would like a chance to try the SolidWorks solution. I don't think the next engine software would be adequate. I would still like to have control over the surfaces after they were created. See the gallery post for the example of the part I made.
lebeau: "I would still like to have control over the surfaces after they were created."
An English marine engineer named Marcus Bole releases his PolyCAD program as freeware at
www.polycad.co.uk . It's superb for mesh to spline surface conversion or vice versa and makes it as simple as it's possible to be to edit (subdivide, rebuild, or simplify, global or local) either surface type manually as opposed to automatically like INUS RapidForm does. IGES surfaces exported from PolyCAD import well into ViaCAD and accept all the usual manipulations. As well, Marcus' .geo format is clear plain english and numerical, so it's possible to create a file purely textually, or import .csv polyline coordinates. PolyCAD is good to work with and plays well with punchcad.
It should be worth mentioning Meshlab here too. Meshlab does pretty much the same thing as Polylab, but also works on Mac OS X (Intel), and is proper freeware ;)
sorry, difference of opinion. Meshlab is semi automatic mesh or subdivision surface manipulation, doesn't work with spline surfaces at all, and doesn't offer the same level of manual control as PolyCAD. Horses for courses, but Meshlab isn't CAD.
Hi Zumer. I'm sorry if I mislead anyone. However I think I was just a little miffed because PolyCAD is Windows only (and isn't really freeware either- as you have to buy it after 30 days is up). When I recommend software here, because I know that there are also many Mac users here too, I try to recommend software that is cross platform, as this doesn't discriminate against those who choose to use OS X. As you probably already know, Tim is probably the only developer around who offers a mid-priced solid modeling CAD package, that can be used for engineering purposes (ala Solidworks), as well as surface modeling, that can be used on Mac OS X as well as Windows. That was all :) Tom.
It doesn't address the PC-only thing, but PolyCAD IS free. It's stated on Polycad's home page, at right, near the top of page. Marcus does require that users register it after a month, but at no cost. I use the free David laserscanner system, and Meshlab helps out with cleaning raw data, but it doesn't give usable finished geometry, and it sounds like the Nextengin software doesn't either. I've seen impressive direct scan-to-near-finished-surface results from Rainbow Geometric and INUS RapidForm, but they're both out of my price range, so I've got to use the tools available to me. However, taking geometry numberically into Polycad from .obj is quite easy, and PolyCAD gives NURB handling features that are as powerful or more so than the big dogs, but not as automatic. I'm more used to working with conventional (AutoCAD and similar) CAD, so I do find PolyCAD's user interface to be more intuitive than much of ViaCAD, but intuition is a subjective thing.
zumer wrote: However, taking geometry numberically into Polycad from .obj is quite easy, and PolyCAD gives NURB handling features that are as powerful or more so than the big dogs, but not as automatic.
Zumer,
Thank you for your post. I am new to CAD world and Shark/ViaCad are the only
applications I have used so far. Do you know of any tutorials for noobs on the process of turning obj/stl scanned objects into Nurbs Surfaces in PolyCad?
Mark
zumer wrote: IGES surfaces exported from PolyCAD import well into ViaCAD and accept all the usual manipulations.
Zumer,
Are you sure about ability to perform usual operations with IGES surfaces imported to Shark/ViaCad?
Not knowing PolyCad well enough I have used demo version of Rapid Works to automatically create IGES surface from scan and imported to Shark/ViaCad, but there is not much I can do with it.
What am I doing wrong?
Mac OSX10.5, Shark/ViaCad
Tim, Can you help to define what type of operations we should be able to perform on IGES Surfaces imported to Shark/ViaCad? Mark
Mark wrote: Not knowing PolyCad well enough I have used demo version of Rapid Works to automatically create IGES surface from scan and imported to Shark/ViaCad, but there is not much I can do with it.
Zumer,
You are absolutely wright. There is a lot I can do with IGES Surfaces in Shark/ViaCad. My setup for testing was wrong.
Mark
Zumer,
You are absolutely wright. I have used Rapid Works demo to automatically convert scan data to IGES Surfaces. After importing IGES to Shark/ViaCad I can do almost anything with it. Using PolyCad to convert stl/obj scan to IGES Surfaces is still a mystery to me.
Can you help to figure this one out?
Mark
Mark, give me a couple of days and I'll patch together a demo and some instructions. It's not hard, except that in some cases entities are complicated and need to be reduced to be workable.
zumer wrote: I'm more used to working with conventional (AutoCAD and similar) CAD, so I do find PolyCAD's user interface to be more intuitive than much of ViaCAD, but intuition is a subjective thing.
Indeed! It's nice too, to hear from folks who are passionate about their software! :D
I know it's OT, but have you seen Ribbonsoft's QCad? QCad is very similar to ACAD, but is far easier to use and a years licence only costs 13 (Multiplatform too!)
zumer wrote: Mark, give me a couple of days and I'll patch together a demo and some instructions. It's not hard, except that in some cases entities are complicated and need to be reduced to be workable.
Thank you very much.
Mark
Surface Modeling
