Thanks: 1 times Was thanked: 4 time(s) in 4 post(s)
Here is an example problem I am trying to solve:
1. Created attached "Solid slab" model with series of angled surfaces.
2. Changed object type to "Surfaces"
Now I am trying to place all resulted surfaces horizontally in XY plane, so I can later generate CNC Machine Code for cutting them in laminate sheet.
I can't find the way to do it in Shark?
Any suggestions are highly appreciated.
Solid slab.sfx
(190kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Intel iMac-20,2 | macOS Ventura 13.3.1 | SharkCAD 14 |
Thanks: 195 times Was thanked: 163 time(s) in 112 post(s)
Mark,
First of all thats a big sheet 60" X 72". I selected all, Model-to-Sheet, delete unwanted views, delete border and title block. Flatten the view and change the lineweight, using obj. pen, I used .002". Export as .dxf.
I use Sheet-Cam and usually cut individual pieces, which creates the problem of having to draw and mark your pieces one-by-one. I opened your drawing in Sheet-Cam, just to see if this is what you're looking for. I might be way off base on what you want to do. The screen shot is from Sheet-Cam.
(112kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: Mark Here is an example problem I am trying to solve: 1. Created attached "Solid slab" model with series of angled surfaces. 2. Changed object type to "Surfaces" Now I am trying to place all resulted surfaces horizontally in XY plane, so I can later generate CNC Machine Code for cutting them in laminate sheet. I can't find the way to do it in Shark? Any suggestions are highly appreciated.
Hi Mark,
I currently use VC and there is not facility in there....same with Shark from what you say.
In Rhino I can "unroll" (flatten) surfaces, I believe this would work on your part but I cannot open it to try it;). Checkout attached file by importing the Rhino file into Shark (check the heal auto heal solids box), Then select all items and change display to U&V=1
I would be happy to try your file if you save out as VC or ACIS - Happy Xmas!
example.zip
(29kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: unique Hi Mark, I would be happy to try your file if you save out as VC or ACIS - Happy Xmas!
Thanks to all for advice. It looks like Rhino can solve a lot of my problems.
unique, Attached is ACIS 6.0 version of the model to try in Rhino.
Thank you.
Surfaces.sat.zip
(101kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Hi Mark,
Sorry mate..totally missed your post!!:o:o
Checkout the file attached it has 159 facets:eek:
facets.sat.zip
(137kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
