macnavi
#1 Posted : Tuesday, September 18, 2012 2:49:40 PM(UTC)
macnavi
Netherlands
I switch a lot between the Wireframe and Shaded mode and I really would like a short cut. Adding the short cut in the Short Cut preference doesn't work, as they will both select, and what ever you push, the result is always only a Shaded image. The blue highlight colour of the tool selected is actually showing that both tools are selected at the same time. Which is impossible to do when you click with the mouse on it.
What happens here? Bug or user mistake?
#2 Posted : Tuesday, September 18, 2012 9:07:28 PM(UTC)
Mexico
There are some keys reserved for internal code on shark, example, "w" is for zooming window (auto toggle to actual used tool, very handy), so you can not use it for wireframe, as well as other ones that are reserved also.
I set "8" for wireframe and "h" for shaded and works fine, not fail or bug at all.
MacOSX Sequoia 15.7.7
macnavi
#3 Posted : Tuesday, September 18, 2012 10:42:41 PM(UTC)
macnavi
Netherlands
Thanks for the reply. No, same issue.
I made a video of it, you can see it here:
http://www.youtube.com/watch?v=hETlZpK9EQo
In the video, I'm intermittently pressing 8 and H.
As you can see, it does change in the info space on the top left of the screen, but the Shaded icon always stays selected.
